What affects Thetis Boot-up time?
AB5N
Post by AB5N »
When I first set the 7000DLe II and Thetis up, it took about a minute to boot.
Now at one month in, it takes almost three minutes to boot.
I am using DHCP on both ends.
Anyone have knowledge of what affects boot up time?
Thanks- Bob-AB5N
Re: What affects Thetis Boot-up time?
Mine has consistently taken 20 seconds every time. I am using v2.7.0 a3. I know in some older versions the forms took a while but somewhere along the way Ritchie improved that a lot.
I am using a 7000DLE and static IP's on both ends FWIW.
AB5N
Post by AB5N »
Gotcha- Well, I did a full re-boot and it shortened it up again. I'm actually wondering if using DHCP on both ends lengthens the boot time?
I'm reticent to go with fixed IP on both ends as I originally tried it and failed. I'm having so much fun with the radio, I don't want to make it a 4 Advil afternoon.
I wonder if anyone knows this answer...?
Bob
Network configuration has nothing to do with it. It is strictly related to CPU and disk drive speed. On my i7-7700 with SSD it takes exactly 10 seconds.
The variations in time you are experiencing may be due to other software using your CPU.
AB5N
Post by AB5N »
QSL-
Using an I7 Lenovo Laptop with SSD. Works well.
Onwards!
Tnx-
Bob
rbduck
Post by rbduck »
For what it's worth my Thetis boots in 14 seconds. I'm measuring from the moment Thetis is started until the time it's available to power up. I actually have Thetis starting after the computer boots. I have several programs that start sequentially from a batch file in a specific order. 15 Seconds is the time I allow Thetis before starting the next application.
FM5GB
Post by FM5GB »
Hi All !
Bootup takes less than 12 seconds (Thetis 2.6.9. I7-4770 K.@3.5GHz, 24 GB RAM; 0.5 TB SSD. Network & radio with fixed IP)
This fast bootup has been since the last Win10-64pro update some weeks ago; before it was much slower as was all my software unfortunately
I did'nt make a comparative check.
73s Phil FM5GB
W4GM
Post by W4GM »
Bootup here takes approximately 10 seconds. Thetis 2.70a3 , Firmware 2.0 , Computer AMD Ryzen 3.6 Processor, 32 GB Ram, AMD Radeon RX580XT 8GB Graphics and .5 TB SS Hard disk. Using a static ip here and computer is dedicated to my Anan 7000DLE MKII .
W4GM
Mine takes a hair over 8 seconds. Thetis 2.70a3 , firmware 2.0. Computer is 5 year old i7-6700K slightly overclocked to 4.3GHz, Win10 Home, 16GB ram, Nvidia GTX-970 graphics, puny 240 GB Intel 535 SSD. Computer is tied directly to the 7000DLE MKII with CAT7 cable via static IP, no router or switch.
W3MMR
Post by W3MMR »
just under 10 here, every single time. PowerSDR 3.4.9 took about 15 seconds. 200d, P2 1.9, 2.7.0a3, Dell i7 4770, SSD, Nvidia 1050ti, 16gb, dual 27" 1440p monitors.
I did however notice that it was getting longer to boot. Maybe up to 12-13 seconds. But it was time for a fresh install after 7 months(i do a lot of clicking and changing things, and screwing stuff up lol) and after that, it went back down to about 9 or 10 seconds
w3mmr
