Forgive me if this has been covered elsewhere, but I recently tried using the space bar to key the 7000 DLE MKII via PowerSDR mRrx.
I was immediately told that my audio was "severely distorted"...
Has anyone else had this occur? I just got the latest batch of RX audio glitches fixed by removing VirtualBox and Wireshark, but this one has me puzzled.
Also: I'm not "holding" the space bar, just pressing it once to key and once more to un-key. PTT via the rear apron PTT connector works without issue.
Jim N7CXI
Space bar MOX causes TX audio garbage?
Re: Space bar MOX causes TX audio garbage?
I can not begin to fathom how the method of PTT could possibly affect your audio in any way.
I can't either.w-u-2-o wrote:I can not begin to fathom how the method of PTT could possibly affect your audio in any way.
What *appears* to be happening is that pressing the space bar is causing some PowerSDR thread to stutter. Why or how I don't know.
If I have time this weekend I'll un-install PowerSDR, remove everything relevant from the AppData folder or folder, re-install and try again.
I already tried exporting and re-importing the database with no effect.
The only other thing I've thought of that I haven't tried yet is rebooting the (1Gb fabric) L2 switch between the rig and the PC. I'll do that, if I can get my wife away from the TV long enough to allow it.
Jim N7CXI
"Stutter". Now there's a word that is a clue.
You are chasing after zebras. Look for horses.
Is it a USB keyboard or wireless? I bet it's USB and you've got RFI on the USB line causing the PTT to go crazy. Change to a wireless keyboard. They all run at 2.4GHz and are generally immune to HF RFI.
Thanks, Scott.
I wish it were that easy. The keyboard is wireless and RF levels in the shack are generally very low. I can hear it in a monitor receiver when transmitting into a dummy load.
Aargh. I think I will try a different keyboard tho. That machine has a fancy Logitech ergo-whatever on it, and it’s easy to do and check off the list. Thanks for the idea.
Jim N7CXI
Jim N7CXI
Hello Jim, i would like to know.....was it your keyboard?
73 Leon
73 Leon
Hi Leon,
Sorry about the delay replying.
Unfortunately, I don't know. i've since moved over to Thetis-x64, and at least so far the keyboard PTT hasn't worked at all.
It probably *does* work, but just setting the spacebar selection under "Keyboard" to "PTT/MOX" doesn't do it. I don't have
much time to operate, so I haven't run across the right "enable thisorthat" checkbox yet.
Given the many advantages Thetis brings, I probably won't be going back to PowerSDR mRx.
When all else fails, change the equation, I suppose.
Jim N7CXI
Jim N7CXI
... and I just found the checkbox:
Setup->Options->Options-1->Keyboard[Enable Shortcuts]
Now to find out if the odd audio behavior followed me here.
Jim N7CXI
Jim N7CXI
