Anan 10e fpga heatsink size
nubbyless
Post by nubbyless »
Hi does any one know of a schematic for the 10e so I can look up the exact fpga size I know it's a EP3C25 but there seems to be several packages I would like to add a stick on heatsink to it. I have seen some pictures where people have done this maybe someone knows what size I should purchase.
Fred
Re: Anan 10e fpga heatsink size
Did you not notice the schematics section of this forum?
nubbyless
Post by nubbyless »
thanks i searched and searched google and never found it i assumed if it was here i would of seen it in a google search but i was wrong sorry about that.
But after looking at that schematic it shows the ALTERA EP3C40Q240 which i believe is in the anan 10 not the 10e. although it may be the same size if the radios are identical otherwise
You are correct, that is the part used on the 10, they used the EP3C25 in the 10E to reduce cost.
I can only guess that they bought the same package type for the smaller FPGA so the board didn't have to be revised and got lazy on the schematic.
