Two midi controllers at same time?
N4XD
Post by N4XD »
Is it possible to have 2 controllers connected to the Anan (in my case the 7000dle Mk2) at the same time controlling different things in Thetis?
Ron
N4XD
Re: Two midi controllers at same time?
Yes, that will work. But any function can only be assigned to a single MIDI control.
W2PA
Post by W2PA »
To clarify just a bit, Scott is correct, a function can only be assigned to a single control on any single controller. You can, however, assign the same function to controls on different controllers (once for each controller). I do this with the Behringer PL-1 and Micro.
Chris, W2PA
