VAC toggles off when AM or SAM mode selected
W4NNG
Post by W4NNG »
Just updated to v2.8.11
VAC now toggles off when AM or SAM mode selected. Clicking VAC1 will enable it. Selecting all other modes VAC1 stays enabled.
Problem is repeatable even during same session
If, for example, AM selected > re-enabling VAC > select LSB > AM = VAC1 will toggle off again.
PD3LK
Re: VAC toggles off when AM or SAM mode selected
Post by PD3LK »
i remember this setting is saved in the TX profiles or did you tried that?
The problem is that the mic that you last associated with AM mode is remembered for that mode (as it also is for the LSB and USB modes), and all of the settings specific to that mic's Profile get reinstated every time you change to that mode. So Save the Transmit Profile for the mic in question after you've set the various parameters (VAC, sample rate, filter width, etc.) as you want them for AM mode. That way you'll automatically come up in all those settings whenever you change to AM mode in the future.
W4NNG
Post by W4NNG »
K1LSB wrote:The problem is that the mic that you last associated with AM mode is remembered for that mode (as it also is for the LSB and USB modes), and all of the settings specific to that mic's Profile get reinstated every time you change to that mode. So Save the Transmit Profile for the mic in question after you've set the various parameters (VAC, sample rate, filter width, etc.) as you want them for AM mode. That way you'll automatically come up in all those settings whenever you change to AM mode in the future.
Thanks Mark and Leon -- Solved problem and I learned a more about what goes in the Xmit profile.
