Noise cancelling / Phasing using diversity
Has anyone used the Diversity feature in Thetis in order to emulate the noise function of popular phasing / noise reduction units such as the MFJ-1026, QRM-180, ANC-4, NCC-2 or Quantum phaser?
If so, could you kindly reply w/ how you did it, including the type of noise antenna you used? Will Thetis / Anan automatically protect the front end of RX2 during transmit, if RX2 was being used as a noise antenna input? Seems like it almost certainly will, but am asking because this is potentially a source of catastrophic failure.
If it works, could be an exceptionally useful feature for those of us operating in urban environments.
To the mods - I posted this in the "Thetis" section because noise reduction is a general topic of wide ranging interest, compared to the more common use of the diversity feature to steer multiphased antenna arrays. Please move this post to the 'Diversity" section if that is more appropriate.
Taiga
Taiga
Re: Noise cancelling / Phasing using diversity
I can't speak to all those devices, but the MFJ-1026, Quantum Phaser, NCC-2 and ANC-4 do exactly the same thing as "Diversity" in PowerSDR and Thetis. So there is no "emulation", they are all purporting to do the same thing, which is to vector sum the outputs of two receive antennas with variable phase and gain factors, i.e. coherent beamforming. In other words there is nothing special you need to do in order to accomplish the same thing the MFJ, NCC, Quantum and ANC units are doing (and perhaps the other as well but I am not familiar with them).Taiga wrote:Hi,
If ground RX2 on TX is turned on, yes. However I strongly recommend using an external RF limiter like the DX Engineering "Receiver Guard". It's "cheap insurance".Will Thetis / Anan automatically protect the front end of RX2 during transmit, if RX2 was being used as a noise antenna input?
It does work, but only for coherent, interfering signals from a point source in the far field. Did you read this thread: https://apache-labs.com/community/viewt ... =21&t=2362 ??If it works, could be an exceptionally useful feature for those of us operating in urban environments.
Moved itTo the mods - I posted this in the "Thetis" section because noise reduction is a general topic of wide ranging interest, compared to the more common use of the diversity feature to steer multiphased antenna arrays. Please move this post to the 'Diversity" section if that is more appropriate.
I don’t have two identical antennas to phase, but I do use Diversity to cancel noise sources from my own house.
It only works on one source so if you have multiple it’s not going to affect them all.
I use a really crappy fan dipole I made for broadcast FM, 2m and 440 that just hangs in my shack as my “noise” antenna.
It works very effectively to null out the broad band noise the fan motor controller my heat pump generates, and will drop the S5 noise floor over an S3 without it running, down to the S3.
When idle, that same heat pump has a horrific noise the control board radiates and it will greatly reduce the harmonics of that noise...but remember it’s single source so you have to pick the biggest offender and settle for reducing that influence.
I have both an Anan 7000 and a SunSDR2 DX and go between them both frequently. Diversity is a major advantage as well as Pure Signal and being able to listen to multiple antennas...all because the Anan has two ADCs in it. These are the things that give the Anan the edge over the Sun for me.
I use Diversity often to eliminate single-point noise sources, it works superbly. I was using it on 40 meters today to remove a roughly 3khz-wide 30db spike and was easily able to remove literally all evidence of the intruder from the panafall and the received audio....and there was a faint QSO hidden under the spike that suddenly popped out of the background into perfect readability! Awesomely powerful feature....I'll never own another radio that doesn't offer Diversity (or PureSignal, for that matter)....but then again, I'll probably never own another radio except possibly another ANAN, lol.
EDIT: My diversity receive antenna is a simple loop of wire literally laying on the ground. It's roughly 130 feet in circumference, feeding into a coax with a 3:1 isolation transformer. Truly amazing performance, it surprised the snot out of me when I first tried it. It shows very nearly the same S/N ratio as a tuned dipole on all the bands I listen to.
Here's an article on the "Loop on Ground" antenna (though mine's a tad bigger than the one in the article):
http://www.kk5jy.net/LoG/?fbclid=IwAR0d ... B9h5T4NGyU
DISCLAIMER: I am not hesitant about stating that electronics and technology are not my areas of expertise - but I work hard to acquire new knowledge and apply that knowledge.
Now then, I am just now experimenting with Diversity Reception. I have a SteppIR Urban Beam at 45' - that covers 6m-40m (It works as a dipole on 30m-40m) and an 80m Dipole at 36' - but my plan has been to add an 80/40/20m Fan Dipole at 80' (in a tree that is on the opposite side of the house where my tower is placed.)
I recently worked an African station on 40m, at 4:50 UTC. It was virtually impossible to complete the contact, but we were finally able to exchange 3-3 reports. I heard a US station say that the African station was supposed to be on the air the following night, at the same time, on the same frequency. It was then that I decided to try Diversity Reception. The next day, with nothing else to use, I connected my 80m Dipole to Rx2. When I heard the African station, I selected "Enabled" and began to adjust the "Phasing Control." The African station seemed to magically rise above all the interference (whatever the source was) and became 100% Readable; additionally, I could hear numerous other stations calling him - stations that I previously had no way of knowing were on frequency. WOW! The bottom line is that I am now working hard to develop my understanding of how to best use Diversity Reception.
QUESTION #1: I assume that because my 80m Dipole had a large capture area, it worked adequately for my purpose. Is this a reasonable assumption?
QUESTION #2: I realize every situation is different, but it seems as if many operators use a loop for Rx2. Is this the best overall, multipurpose receive antenna for my situation as I have described it? If so, I would greatly appreciate input concerning feedline. I have to use coax - is any 50 Ohm coax adequate and what is the best balun to use? Also, I have heard some say they place a loop on the ground, others at 10,' others say to go as high as possible, etc. Finally, some use a 60' loop, with 15' on each side, while I have seen plans that call for giant loops up to 800' (at least for me, that would be a giant loop and not possible). Any suggestions on height for a dedicated Receive Only / Diversity Antenna?
With Appreciation,
David
WR4N
With Appreciation,
David
WR4N
ANAN 7000 DLE MKIII
Best 73s,
WR4N - David
Best 73s,
WR4N - David
No. The reality is you simply got lucky. Since "diversity" in this context = beamforming, you were very luckily able to form a beam in the direction of the station of interest and a null in the direction of some of the interfering signals you might have.WR4N wrote:I assume that because my 80m Dipole had a large capture area, it worked adequately for my purpose. Is this a reasonable assumption?
I've not tried this myself, but it would appear that many folks have had good luck with a rotatable mag-loop for RX2. This allows much more flexibility in terms of "getting lucky", since the rotatable mag loop provides an extra dimension to adjust the relative beam patterns of the two antennas prior to phase and amplitude adjustment.I realize every situation is different, but it seems as if many operators use a loop for Rx2. Is this the best overall, multipurpose receive antenna for my situation as I have described it? If so, I would greatly appreciate input concerning feedline. I have to use coax - is any 50 Ohm coax adequate and what is the best balun to use? Also, I have heard some say they place a loop on the ground, others at 10,' others say to go as high as possible, etc. Finally, some use a 60' loop, with 15' on each side, while I have seen plans that call for giant loops up to 800' (at least for me, that would be a giant loop and not possible). Any suggestions on height for a dedicated Receive Only / Diversity Antenna?
On a couple of bands I utilize pairs of similar inverted vees orthogonal to each other. The notion is that inverted vees tend to favor vertical polarization off the ends and horizontal polarization on the broadsides.
I have done extensive work with both analog and digital diversity reception over the past few years, particularly for simple beamforming and interference cancellation. You can find tons of information and videos about these through my blog Making It Up (at http://play.fallows.ca
In addition to ham antennas, I use a 100' wideband loop array, as well as noise antennas. Receivers include RSPduo, Afedri 2-channel and, of course, ANAN-7000 DLE MKII. Also, you will find direct comparisons with analog phasing boxes X-Phase, ANC-4, MFJ-1026 and NCC-1.
Bottom line is that all the analog and digital approaches do a good job of interference reduction (single point sources, mainly) across HF and acceptable single-lobe/null beamforming on MF and lower HF.
You might also look at my video on Modern Diversity Reception at https://youtu.be/33uJCoTesGc
73 John VE6EY
73 John VE6EY
John,VE6EY wrote:I have done extensive work with both analog and digital diversity reception over the past few years, particularly for simple beamforming and interference cancellation.
That's quite a body of work there. In your role as an evangelist for this sort of thing, I would strongly encourage you to make proper use of the term "diversity". Thetis, and PowerSDR before it, do NOT make proper use of this term, This has badly tainted both people's understanding of the various techniques and done a huge disservice to the professional technical lexicon.
"Diversity" always refers to non-coherent (not dependent on signal phase) techniques of improving signal reception. Beamforming is a coherent (dependent on signal phase) process and should never be confused with diversity techniques.
The mislabeling of the feature in Thetis/PowerSDR is one of the worst things that ever happened, and has hopelessly confused the issue for a large population of hams.
Your use of the term "spatial filtering" is a valid one, but one must be extra cautious to make the distinction between a coherent spatial technique, e.g. beamforming, and non-coherent spatial diversity, e.g. merely switching between two antennas to mitigate multipath effects. In general, and in the technical literature and in professional practice, spatial filtering always refers to beamforming.
Finally, there is no distinction between time delay and phase in the RF world. They are one and the same and it's merely a matter of semantics how those terms are used.
I use a 15' per side, square, "loop on the ground" antenna for my "noise source" antenna. I've tried everything from a long wire, a 75m inverted v, and a G5RV. The LOG antenn has been the best for my local RFI and the bands I normally have issues on (75m and 160m). It works best on 75m. It takes some time to get the hang of adjusting the gain and phase relationships, but once you do, it can work wonders.
Here's an example:
https://youtu.be/Ip6XrlbFZ-k
You can clearly see the noise dissappear and the signals appear. It works wonders for me, but like I said, it took some experimenting. The noise antenna is the most important factor.
Perry
Here's an example:
Perry
Perry,W3MMR wrote:Here's an example
The way you made that video it wasn't easy to appreciate what was on the reference antenna vs. what was on the second ("noise") antenna.
Is there any chance you could make an updated video that demonstrates switching between Rx+Rx2, Receiver 1 and Receiver 2 source modes, all while leaving diversity enabled? When it's demonstrated that way it is then easy to see what's on each antenna, then see how they combine.
I see what you're saying. I was just trying to show the difference with it on and off and my QTH. Unfortunately, that particular source of RFI hasn't been "on" in 6 months or so since I was able to track it down and let the neighbor know there was an issue. I never was able to find out what it was because I left a note on their door with a brief explanation of the issue and to call me. Magically the noise went away a few days later.w-u-2-o wrote:Perry,W3MMR wrote:Here's an example
Ive been dealing with horrendous RFI living in the city. Ive replaced a plasma TV in one neighbors home. I replaced 2 switching supplies in another neighbors home. And when this noise came about, i was getting tired of knocking on doors so that's when i really started to experiment with "diversity" and different RX2 antennas.
Heres the plasma TV interference:
https://youtu.be/vTMXRYg7Jlc
Switching Supply Interference:
https://www.youtube.com/watch?v=Lsun_8hml-E
Next time something comes up and im using diversity, ill make another video showing what you asked. That would be good to show.
Another feature of the Diversity Tab is the ability to instantly swap between Rx 1 and Rx 2 and still retain the Display - as opposed to the split feature if activating RX2 separately (and having to select VAC1 or VAC2)
Simply select either Rx 1 or Rx 2 as the Receiver Source.
- Diversity.jpg (474.6 KiB) Viewed 22416 times
