Have seriously strong (-73dBM) noise that is wide and has recurring peaks spaced ~20Khz. Each occurrence is ~8 Khz wide. My guess is telemetry. It's coming off the power line but I haven't been able to isolate the source. Even good old NR2 is no match.
My lowest noise receive antenna is an 80 meter dipole that has a cable shield isolating balun. (Balun Designs 1116d). Using 'Diversity' to phase steer a notch on the QRN, I tried various 'receive only' reference antennas with marginal notch success.
What did work, and work well, as a reference was my 160 meter (built for power) antenna. It almost completely notched the QRN. I tried background noise floor tuning it with an antenna tuner. That significantly improved the notched cancellation and completely removed the noise.
One addition piece of info - The main antenna also needs to matched before doing the notched steering. My amp (RF-Kit) has a built in ATU. The amp also needs to be put into Operate (vs Standby) before steering the notch. {guess OP mode introduces some phase shift)
Hope this is helpful,
Bob W4NNG
- Board index
- Search
- It is currently Sun Jun 15, 2025 4:29 am
- All times are UTC
Using Diversity to notch out a strong noise source
Jump to
- Apache Labs News
- ↳ Apache Labs News
- Client Software Discussion
- ↳ Thetis
- ↳ piHPSDR
- ↳ PowerSDR mRX
- ↳ linHPSDR
- ↳ SDR Console
- ↳ All Other Clients
- ↳ Digital ("Virtual") Audio
- ↳ Amplifiers & Tuners
- ↳ Transverters
- ↳ PC's & Homebrew Hardware
- Firmware Discussion
- ↳ Upgrading/Downgrading
- ↳ Orion Firmware (200D)
- ↳ Angelia Firmware (100D)
- ↳ Legacy Yahoo Group Files
- Other Topics
- Equipment Exchange
