Read Internal Temperature
W4NNG
Post by W4NNG »
Is there anywhere in Thetis (or anyway) to see the output from any of the rigs internal temperature sensors?
Re: Read Internal Temperature
You can query using hamlib rigctl
rigctl -m 2048 -r com16 -s 115200
Rig command: w ZZTS;
Reply: ZZTS00301;
At least on my ANAN100 the ZZTS command seems to return a constant value of what should be 30.1C -- that number doesn't seem to change.
The ZZDU command shows 00000 for the temp reading so that doesn't match the ZZTS answer at all.
Rig command: w ZZDU;
Reply: ZZDU1:1:0:0:0:0:0:0:0:8:0:0:0:02:07:00:06:10:000:080:059:080:000:025:059:0000:134:+0000:00000:+0000:012.63:00003573000:00003572000;
W4NNG
Post by W4NNG »
Hello Mike
A bit lost. Not clear to me where hamlib command get entered. I we still talking Thetis?
hamlib is not part of Thetis -- it comes with WSJT-X or JTDX and is called rigctl-wsjtx or rigctl-jtdx respectively.
You'll find hamlib by itself here that has rigctgl in it.
https://sourceforge.net/projects/hamlib ... amlib/4.0/
w5wc
Post by w5wc »
There are no provisions to read the internal temperature of any of the radios. The 8000DLE displays the internal temperature on the front panel using a microcontroller but it does not send those results to the software.
Doug W5WC
