SWL list restriction
PD3LK
Post by PD3LK »
HI, it seems there is a limit of 20.000 entries for the SWL list.
You can have more in CVS file but only the first 20k are displayed in Thetis.
20k looks more then enough but Dan Furguson's SWL lists have more entries.
Btw his lists have to be converted before you can use them in Thetis but that's not a issue.
Is there a developer able & willing to delete this 20k restriction or change it to f.e. 40k ?
Re: SWL list restriction
You might be interested in CSVUserListBrowser, a completely awful name for some quite wonderful SWL software that works with PowerSDR and Thetis. With this software it will not only help you find stations, it will also help you identify them, as it will check current receiver settings against the databases, which is very cool.
PD3LK
Post by PD3LK »
Hi Scott, thanks for your reply. Yes i used CSVUserListBrowser before with SDRuno and SDRConsole but stopped using it because i don't use SDRuno anymore and it is very easy to import Dan's freq list directly into SDRConsole. I will give it a try with Thetis though, thanks for the tip.
