Band Stacking and AGC Settings
w3ub
Post by w3ub »
Starting to do more CW work these days. I use two band stacking registers, one setup for SSB, one for CW. I can't seem to make the AGC setting for the CW register stick.
Am I missing something? Is the AGC setting global for that band? It should at a minimum be mode specific? Or band stack specific?
Doug
Re: Band Stacking and AGC Settings
AGC (and a number of other) settings aren't band stack specific, they're saved with Transmit Profile. Whatever TX profile is associated with your CW mode will contain your AGC settings. So select the Transmit Profile you want to use for CW, adjust the AGC settings to your liking then re-save that Transmit Profile. The next time you open that profile the AGC settings will re-load with your preferences.
w3ub
Post by w3ub »
OK ... seems like making RX AGC setting part of a TX profile is a bit odd to me ... it is just as easy to change the AGC setting as it is to load a TX profile, most CW TX settings that I am aware of are simply part of the CW mode selection.
Doug
I agree, it is a bit odd but I can live with it.
w3ub
Post by w3ub »
Yes, I can live with it as well, and thanks for setting me straight, I kept trying things ...
To those who are developing, my two cents, KISS, allow for most items to be contained within a band stack (AGC/Drive/ATT/TuneStep/Transmit Profile/Pan/Zoom/...).
And for those who are developing, THANKS!
Doug
