Thetis installation in a faster PC
I2NOY
Post by I2NOY »
I transferred every program and app to a faster PC and I wonder if I have to instruct Thetis it is running in a faster hardware.
I remember that Thetis, at first launch, opened a command window and calculated speed of FFT with different parameters.
Is it possible to make a new calculation that fits better new hardware?
If I uninstall Thetis on new PC and install again, he will perform again the FFT speed routine?
Thanks for any help. :)
Re: Thetis installation in a faster PC
I2NOY wrote:If I uninstall Thetis on new PC and install again, he will perform again the FFT speed routine?
That is correct.
Uninstalling removes the config info? I didn't think it did.
All you really need to do is delete wdspWisdom00
It's in \Users\[username]\Appdata\Roaming\OpenHPSDR\Thetis
I2NOY
Post by I2NOY »
Many thanks, I will try removing only wdspWisdom00 in \users\... folder. ;)
P.S. it worked perfectly! :D
