SPE Expert 1.5k V2 issues with dual tone and PureSignal 2 (7000DLE MK2)
I2NOY
Post by I2NOY »
in my Thetis x64 latest release and protocol 2 (2.0b) setup, as soon as I send the 2 tones to linear amplifier, it is making a lot of beeps and on display it writes that I am trying to emit on a not permitted frequency and switches off power (0 W out to antenna).
I tried in 10 and 6 m and same result. I used low power setting and output from 100 to 500 W.
With single tone it is perfect; with two tones and consequent odd IMD signals, the linear amplifier always writes that I am transmitting in a wrong frequency.
I tried with and without feedback from linear amplifier
So it is impossible to use and setup PureSignal 2 with linear amplifier ON.
Any suggestion? :shock:
kc2rgw
Re: SPE Expert 1.5k V2 issues with dual tone and PureSignal 2 (7000DLE MK2)
Post by kc2rgw »
Sounds like RF in the shack, what is the antenna system, the matcher, feedline and antenna?
What kind of amp is it? Acom amps have a known problem with two tone.
Per the thread title it's a SPE Expert 1.5K V2
DO2ZA Erwin
Post by DO2ZA Erwin »
Hi Mark,
please try Two Tone Test with 700 Hz and the second Tone with 890 Hz.
May be that the Frequency-Counter in the Amp has a Problem with the regular Test.
73 Erwin
Edit: Level at 0.000 db
w3ub
Post by w3ub »
No problems with my 2kFA. Or my earlier 1.3kFA. Seems a bit odd for sure.
Doug
I2NOY
Post by I2NOY »
With 700 and 890 Hz it works perfectly! :D
Many thanks for suggestion.
