Anan 7000DLE MKII black 6 m LNA
Posted: Mon Jul 12, 2021 3:46 pm
by I2NOY
I fear my 6 m LNA is dead.
I was receiving 6 m band during a far thoundstorm and suddenly the receiver drop gain of about 40 dB.
Below pictures of today situation.
Setup LNA ON.jpg (67.41 KiB) Viewed 8287 times
LNA ON.jpg (109.22 KiB) Viewed 8287 times
Setup LNA OFF.jpg (67.29 KiB) Viewed 8287 times
LNA OFF.jpg (155.53 KiB) Viewed 8287 times
I think the LNA is dead.
When I switch in setup between the 6 m LNA ON and OFF, I hear a relé click everytime.
Where is located the 6 m LNA component? Someone has a picture of the board and location of it?
Just today I received the schematics. I think the component is U14 and/or U15 (PGA-103+) located on PA Filter board.
6m LNA.jpg (62.72 KiB) Viewed 8287 times
Do you suggest other tests to prove it is really defective?
Is it so sensitive? I have a 6 el. LFA yagi, so it is electrically in short circuit and the cable is connected to a linear amplifier, so not directly to Anan.
Many thanks for help. :)
Re: Anan 7000DLE MKII black 6 m LNA
Posted: Mon Jul 12, 2021 4:23 pm
by Tony EI7BMB
A few years ago I had the same situation where the 6m LNA just failed for no apparent reason on my Anan 100 . It was an SMD component which was replaced but did not fix the issue so the Anan 100 had to go back for service .
For some time i have been running without the LNA activated on my 7000 mk2 and i find very little difference in SNR so perhaps you might wait until 6m E's season is over before carrying out repairs.
Posted: Mon Jul 12, 2021 7:05 pm
by I2NOY
Many thanks Tony.
Normally I would not use pre on 6 m but for a mistake I cooked the pre near the antenna and so I switched ON the Anan one.
I will decide if I keep my RTX without a working pre on 6 m or I can try to repair the issue with a new component, checking if sourrounding capacitors, resistors and coils are ok.
It is a pitty as the RTX is only 2 months old.
Posted: Mon Jul 12, 2021 7:26 pm
by Tony EI7BMB
Sorry to hear its only new , mine failed after a few months also . I made up a temp pre amp with ha8et unit and coax relay but honestly i really did not need it as have QRN here.
Posted: Tue Jul 13, 2021 8:35 am
by I2NOY
I have a lot of noise too in Milano city :( but I have 48 m of coax cable and I lose about 2.5 dB if I don't use a pre.
I hope filter unit is easy to reach once I open the radio.
If I have time, during the WE I will try the repair. :mrgreen:
P.S.: as 7000DLE is a dual receiver, this evening I will try to see if 6m LNA of second receiver is working or not.
Posted: Mon Jul 19, 2021 9:02 am
by I2NOY
After some bad words :D , I was able to change U14 and now the RX1 6 m LNA is working properly.
I found the component case broken, like a short circuit on power supply inside it.
Not understanding why this happened.
It may be a defective component not enough seasoned. ;)
Posted: Mon Jul 19, 2021 10:14 am
by Tony EI7BMB
Glad you got it fixed
Posted: Mon Nov 08, 2021 11:02 am
by w4bf
Please tell me the email you used to request schematics of the 7000. I've asked more than once to support@apache-labs.com and no reply, even to my spam box.
I have a 7000 received in Sept 2021.
Posted: Wed Nov 17, 2021 4:16 pm
by I2NOY
Hi, I requested the schematics 3 times to support and 2 times to aprakash@apache-labs.com. I received them from aprakash.
Posted: Wed Nov 17, 2021 4:36 pm
by w4bf
Thanks - will contact him with my request.
