TX Profiles
JJ4SDR
TX Profiles
Post by JJ4SDR »
I see there is a plethora of "TX Profiles" available. Trying one just now and after I selected one and pressed ENTER the radio produces no audio whatsoever. Reverting back to my own TX Profile that I was using prior to the "switch" everything works.......This must be yet another elementary newbie mistake that is so obvious that it is laughable :lol:
Best!
ANAN 7000 DLE MKII (Thetis v.2.8.11)
Re: TX Profiles
A TX profile affects a great many settings. So the TX profile may change between mic, line, VAC, etc., as well as other settings that might completely negate your audio.
None of the supplied profiles are useful per se, but you might find one you like by accident.
JJ4SDR
Re: TX Profiles
Post by JJ4SDR »
Thanks Scott! As I said, a rather an elementary reason and what I should have realized, newbie or not :roll:
DO2ZA Erwin
Re: TX Profiles
Post by DO2ZA Erwin »
Hi Juha,
if you use Thetis 2.8.11 21e ore newer, you have a ticking Box on the Setup/Transmit Card, Highligt TX.. Save Items.
Then you can see what is saved with the TX-Profile
73 Erwin
JJ4SDR
Re: TX Profiles
Post by JJ4SDR »
DO2ZA Erwin wrote:Hi Juha,
73 Erwin
Schoenen Dank Erwin! Will check it out!
JJ4SDR
Re: TX Profiles
Post by JJ4SDR »
Hello Erwin,
Thetis version is 2.8.11.0
JJ
