TX Profiles
Posted: Sun Aug 08, 2021 7:53 pm
by JJ4SDR
I see there is a plethora of "TX Profiles" available. Trying one just now and after I selected one and pressed ENTER the radio produces no audio whatsoever. Reverting back to my own TX Profile that I was using prior to the "switch" everything works.......This must be yet another elementary newbie mistake that is so obvious that it is laughable :lol:
Best!
ANAN 7000 DLE MKII (Thetis v.2.8.11)
Re: TX Profiles
Posted: Sun Aug 08, 2021 8:11 pm
A TX profile affects a great many settings. So the TX profile may change between mic, line, VAC, etc., as well as other settings that might completely negate your audio.
None of the supplied profiles are useful per se, but you might find one you like by accident.
Re: TX Profiles
Posted: Sun Aug 08, 2021 10:21 pm
by JJ4SDR
Thanks Scott! As I said, a rather an elementary reason and what I should have realized, newbie or not :roll:
Re: TX Profiles
Posted: Mon Aug 09, 2021 4:13 pm
by DO2ZA Erwin
Hi Juha,
if you use Thetis 2.8.11 21e ore newer, you have a ticking Box on the Setup/Transmit Card, Highligt TX.. Save Items.
Then you can see what is saved with the TX-Profile
73 Erwin
Re: TX Profiles
Posted: Mon Aug 09, 2021 11:18 pm
by JJ4SDR
DO2ZA Erwin wrote:Hi Juha,
73 Erwin
Schoenen Dank Erwin! Will check it out!
Re: TX Profiles
Posted: Wed Aug 25, 2021 11:16 pm
by JJ4SDR
Hello Erwin,
Thetis version is 2.8.11.0
JJ
