Why does TX EQ revert to ON?
Posted: Fri Aug 20, 2021 9:02 pm
by JJ4SDR
I have been enjoying playing with different audio processing tools now that I got Live Professor 2 (VST Host) working with Thetis, but I am puzzled by the TX Equalizer setting. When I created the TX profile (I didn't save the TX profile per se) I switched off the TX Equalizer completely, but after switching Thetis and the hardware unit off and switching everything back on I see that the TX Equalizer box (in Thetis) is checked although I left it unchecked. I exported the Data base as well for me to load it later as I also process audio using the wonderful tools inside Thetis only. I obviously use a different Data base in that scenario.
Thoughts?
JJ
Re: Why does TX EQ revert to ON?
Posted: Fri Aug 20, 2021 9:15 pm
TX EQ on/off state is stored in the tx profile
You can select an option in setup to highlight everything that is stored in a TX profile, for checking purposes.
Posted: Fri Aug 20, 2021 9:24 pm
by JJ4SDR
Wow! You are fast :)
Thanks a lot!
JJ
Posted: Fri Aug 20, 2021 9:28 pm
by JJ4SDR
ramdor wrote:TX EQ on/off state is stored in the tx profile
Hey,
I don't see the parameters below at all behind the Transmit tab.
Posted: Fri Aug 20, 2021 9:57 pm
Hey,
https://apache-labs.com/community/viewt ... f=9&t=3817
Posted: Sat Aug 21, 2021 3:32 pm
by JJ4SDR
Not sure if this has anything to do with my observation but I am using P1 and will only start using P2 once I am much more familiar with Thetis.
Best!
JJ
Posted: Sat Aug 21, 2021 4:07 pm
JJ4SDR wrote:Richie,
Best!
JJ
The link was to the beta/patched version of Thetis which can run P1 or P2. The beta includes the check box for highlighting TX profile items, amongst many other things.
Posted: Sat Aug 21, 2021 9:37 pm
by JJ4SDR
Best!
JJ
Hi Richie!
Thanks for the clarification. When I clicked on the link a page chock-full of items came up so (newbie that I am) it was somewhat bewildering to see that :roll: . Also, I have never done operated in other than Thetis v.2.8.11 so I will need to figure our how best get that version loaded (again, I want to stick with P1 for the time being due my inexperience with Thetis).
JJ
Posted: Tue Aug 24, 2021 12:11 am
by JJ4SDR
Hey,
Richie: Does this patch work with Protocol 1 or is it tied to Protocol 2? I am just learning how to walk and won't upgrade to Protocol 2 until after I have learnt how to run? Will need to learn how to run patches too.
Best!
JJ
Posted: Tue Aug 24, 2021 2:03 am
JJ4SDR wrote:
JJ4SDR wrote:
Hey,
Best!
JJ
thetis 2.8.11 and the patches that follow can run both Protocol 1 and Protocol 2.
Posted: Tue Aug 24, 2021 2:23 am
by JJ4SDR
Best!
JJ
As always, thank you Richie!
JJ
