Interrupt Moderation setting on network interface
Here's an interesting one: on my Intel network interface card (NIC) I was doing some speed testing using iperf and was shocked to see the card only moving 150 Mbit/s. This is on a dual NIC, server type, PCIE card, and an i7 CPU, so it should be quite a bit faster.
After poking around in the advanced settings of the network adapter, I found that when I turned off "interrupt moderation" the transfer rate went up to 930Mbit/s! Needless to say I was quite pleased!
I'm not sure this has any real bearing on the performance of our radios, but I'd rather have a faster card than a slower card.
BTW, the challenge for this kind of testing is to have the iperf server running on something you trust to be faster than the PC you are testing. I installed iperf on my QNAP NAS server that has a 2Gbit connection to my switch and that worked quite well as a trusted server platform.
Re: Interrupt Moderation setting on network interface
Found some suggested ethernet settings on this page from Flex https://helpdesk.flexradio.com/hc/en-us ... erformance
Very interesting, Scott.
Funny thing: I have here 6 different PCs in my network... I started the tests on my htpc in the livingroom and noticed 97Mbit
Some quick checks (cable, switch) revealed a NIC issue, so I replaced the NIC and all is fine now (961 MBit), Maybe I wouldn't have figured it out without your post
Just made some tests on all my clients. Speed is ~960MBit. Here on my environment this setting does not change the speed at all.
https://www.oe3ide.com
I don't agree with all those settings, but it's a pretty good list, nonetheless. I'd leave buffer sizes at stock settings and, unless your CPU is very highly utilized, leave all offloading settings turned on. However any differences should be quite minimal either way.Tony EI7BMB wrote:Found some suggested ethernet settings on this page from Flex https://helpdesk.flexradio.com/hc/en-us ... erformance
Another thing that I've had good results with, if you have a dedicated NIC that is only connected to the ANAN, is to go into the properties for that dedicated, single purpose NIC adapter and turn off ALL services EXCEPT for IP4 and PCAP. You could even turn off PCAP (if installed) but then Bootloader won't work when you need it.
Will try your suggestion Scott and turn off unused item on the dedicated NIC for the Anan. This NIC is still showing as a public network even though I've changed it in the registry to private, any suggestions on that ?
Now that you have replaced that two-port PCIe NIC, you should try and repeat your experiment on the "Interrupt Moderation" setting to see if you get the same results as before?
73, Bryan W4WMT
73, Bryan W4WMT
I have no idea. I don't mess with registry settings like that. I would guess, however, that this is a firewall rules issue. You might change your registry back to stock and look at the Windows Defender firewall setup instead.Tony EI7BMB wrote:Will try your suggestion Scott and turn off unused item on the dedicated NIC for the Anan. This NIC is still showing as a public network even though I've changed it in the registry to private, any suggestions on that ?
Very insightful! I didn't think of trying that!W4WMT wrote:Hi Scott,
73, Bryan W4WMT
And, as I suspect you are expecting me to report, the new NIC works 100% fine, super-fast, with Interrupt Moderation turned back on.
Interesting! Perhaps a good indicator of bad NIC in general?
Found the answer to change network type here https://www.itechtics.com/change-networ ... indows-10/w-u-2-o wrote:I have no idea. I don't mess with registry settings like that. I would guess, however, that this is a firewall rules issue. You might change your registry back to stock and look at the Windows Defender firewall setup instead.Tony EI7BMB wrote:This NIC is still showing as a public network even though I've changed it in the registry to private, any suggestions on that ?
I used method 3 "3- How to change Network Type using Local Security Policy"
Ha! No expectations here. Just curious, that's allw-u-2-o wrote: And, as I suspect you are expecting me to report, the new NIC works 100% fine, super-fast, with Interrupt Moderation turned back on.
