Elecraft CP1
Bagabonz
Elecraft CP1
Post by Bagabonz »
Has anyone used the Elecraft CP1 for Puresignal ? DXengineering has these in stock whereas the Xtronics unit is backordered on HRO.
https://www.dxengineering.com/parts/ect-cp1
Re: Elecraft CP1
It's not clear what kind of coupling gain flatness it has over 1-30MHz, so watch out for any major gain variations.
Obviously it is only good to 250W when built as a 30dB coupler.
Assuming you are using a 100W radio, even built for a 30dB coupling factor you will still require an additional 10dB of attenuation on the coupled port for a total of -40dB relative to the input signal so that all inputs to the back of the ANAN remain below +13dBm.
With those caveats it ought to work.
