display jumps to center on transmit
N4XD
Post by N4XD »
Somewhere there is a selection that turns this (xmit freq jumps to center of panadapter when transmitting) on and off. Found it once but can't seem to find it again.
Running Thetis 21k8.
Where is it tucked away?
Ron
N4XD
Re: display jumps to center on transmit
CTUN
N4XD
Post by N4XD »
Scott as always, thanks.
I wasn't complete in my description.
More descriptive note on issue.
When I transmit the display brings the transmit freq to the center of the panadapter. When I stop and switch to receive the display reverts back to how it was before. An example. I'm listening on 1828 which is near the right edge of the panadapter display. I transmit and 1828 is now centered on the panadapter. Switch back to receive and 1828 is once again near the right edge. I don't want the display to jump around like that.
Ron
Turn DUP on.
Post by K9RX »
Hey Ron, Possible you are running JTDX? If so it might be it is causing the shift. When I go SPLIT and I have it on it returns the freq back to transmit. I have to remember to close JT when going split.
N4XD
Post by N4XD »
Thanks for the replies. Scott nailed it. DUP was turned off.
ron
