Thetis Manual Notch Filter Operation
Ctrl right click to add 200Hz
Ctrl shift right click to add 100Hz
Middle mouse to enable/disable a notch
Shift middle to remove
Or +MNF button to add in passband
Drag the edges of a notch if you have enough zoom (although the edges don't highlight right now)
Drag the notch around if you need it moved
You can also right click on a notch to bring up a popup,
W3MMR
Re: Thetis Manual Notch Filter Operation
Post by W3MMR »
Very nice. I was disappointed when using the mouse wheel button to add a notch filter was taken away. But it isnt bad this way.
Perry
W2PA
Post by W2PA »
Also, hovering the mouse over an existing notch enables the mouse wheel to vary the notch's width.
Chris, W2PA
rbanasik
Post by rbanasik »
Thanks for those very helpful tips! -- Bob - Ki1n
