Weird display in VFO B
Posted: Sat Apr 09, 2022 2:54 am
by JJ4SDR
Kind of surprised at seeing "LSB 5.0k" in VFO B. Did get on 15m CW today which is right, but why the rest is out of kilter?
JJ
Re: Weird display in VFO B
Posted: Sat Apr 09, 2022 11:21 am
What should it have said, so we can try to replicate your issue?
Posted: Sat Apr 09, 2022 11:45 pm
by JJ4SDR
It should have said CW with the bandwidth of 1k or perhaps I don't understand this...... I was using XIT trying to work a DX on 15 so I expected a "corresponding" mode indication and bandwidth. Don't understand where the LSB and 5k bandwidth came from as I don't often go that wide on LSB......and I don't often use VFO B (I assume that when I am on VFO A and select the XIT feature VFO B isn't evoked at all.....)
JJ
Posted: Sat Apr 09, 2022 11:49 pm
by NC3Z
How about a screenshot? Otherwise we dont have a clue what you are seeing.
Posted: Sat Apr 09, 2022 11:53 pm
Excellent suggestion, Gary! That would be most helpful, and probably the quickest path to success.
It needs to be of the entire user interface, not just a close up of VFO B
Posted: Tue Apr 12, 2022 8:57 pm
by JJ4SDR
Below, see screen capture.
- VFO B Display.jpg (365.43 KiB) Viewed 5827 times
Posted: Tue Apr 12, 2022 9:21 pm
That is strange. I was not able duplicate that configuration. I put VFO A on 40M. Then I activated RX2 and manually set the frequency, mode and filter bandwidth to LSB and 5K. Then I disabled RX2. VFO B mode and bandwidth reverted to the same as VFO A. Try as I might, I cannot get VFO B to have a different mode and bandwidth from VFO A when RX2 is disabled.
It might be that your database is corrupt somehow. You might try saving it and going back to a reset database to see if the condition persists.
Posted: Tue Apr 12, 2022 10:35 pm
BTW, There have been one or two fixes since 2020.
Code: Select all
21j
fix: labels on VFOB box show correct mode and filter when RX1 is the only rx in use
Yep, old version as per the screenshot......
- OldData_PayItNoMind_C3PO.png (13.49 KiB) Viewed 5802 times
Posted: Thu Apr 14, 2022 4:01 pm
by JJ4SDR
Thanks Richie! Yup....I am using P1, Thetis version that came with my radio still
Posted: Thu Apr 14, 2022 4:23 pm
JJ4SDR wrote:Thanks Richie! Yup....I am using P1, Thetis version that came with my radio still
Yeah, you need to install a new version
