Weird display in VFO B
JJ4SDR
Post by JJ4SDR »
Kind of surprised at seeing "LSB 5.0k" in VFO B. Did get on 15m CW today which is right, but why the rest is out of kilter?
JJ
Re: Weird display in VFO B
What should it have said, so we can try to replicate your issue?
JJ4SDR
Post by JJ4SDR »
It should have said CW with the bandwidth of 1k or perhaps I don't understand this...... I was using XIT trying to work a DX on 15 so I expected a "corresponding" mode indication and bandwidth. Don't understand where the LSB and 5k bandwidth came from as I don't often go that wide on LSB......and I don't often use VFO B (I assume that when I am on VFO A and select the XIT feature VFO B isn't evoked at all.....)
JJ
How about a screenshot? Otherwise we dont have a clue what you are seeing.
Excellent suggestion, Gary! That would be most helpful, and probably the quickest path to success.
It needs to be of the entire user interface, not just a close up of VFO B
JJ4SDR
Post by JJ4SDR »
Below, see screen capture.
VFO B Display.jpg (365.43 KiB) Viewed 5819 times
That is strange. I was not able duplicate that configuration. I put VFO A on 40M. Then I activated RX2 and manually set the frequency, mode and filter bandwidth to LSB and 5K. Then I disabled RX2. VFO B mode and bandwidth reverted to the same as VFO A. Try as I might, I cannot get VFO B to have a different mode and bandwidth from VFO A when RX2 is disabled.
It might be that your database is corrupt somehow. You might try saving it and going back to a reset database to see if the condition persists.
BTW, There have been one or two fixes since 2020.
Code: Select all
21j
fix: labels on VFOB box show correct mode and filter when RX1 is the only rx in use
Yep, old version as per the screenshot......
JJ4SDR
Post by JJ4SDR »
Thanks Richie! Yup....I am using P1, Thetis version that came with my radio still :lol:
JJ4SDR wrote:Thanks Richie! Yup....I am using P1, Thetis version that came with my radio still :lol:
Yeah, you need to install a new version ;)
