JJ4SDR wrote:Paul,
I have no idea what that "Master....." dll file is all about. Never heard of it.
On which form do you enable the CW side-tone to be recorded?
I am all VAC here and it bugs me to have to don another pair of "cans" just to hear the side-tone (that pair is plugged into the front "Headphones" port on my ANAN 7000 DLE MKII.
JJ
First, ignore my reference to the experimental ChannelMaster.dll file. It's not required to record a QSO with your CW sidetone.
Are you attempting to record your QSO with CW sidetone in QSK or Semi-Break-In mode?
To test with a clean slate, I just re-installed Thetis 2.9.0.6. While in CW QSK mode, I pressed the REC button, sent out a test message over the air and stopped REC. I then pressed PLAY and the receiver together with the CW sidetone played back fine.
Semi-Break-In CW was tried next. After setting a reasonable CW delay time, I tried recording the receiver and the CW sidetone. No go. The receiver records fine but not the CW sidetone.
So, try it in full QSK mode. If you don't like to hear the receiver between each keyed element, then delay the receiver recovery time in <Setup><DSP><CW>. Ensure that the QSK box is selected, then increase the Delay setting to a value that works for you.
