Firmware
LA0GE
Firmware
Post by LA0GE »
Hi.
I have just bought a 100D with firmware 3.7.
Whats the latest and greatest firmware for the 100D?
I'm using the latest version of Thetis now.
Bent LA0GE
Re: Firmware
For Protocol 1 firmware, which is what you should probably start with, your answer is right here in this forum where you posted:
For Protocol 2 firmware, that's a much more complex topic. It is best if you read the "New Protocol explained" and Angelia "tacked" topics at the following link first:
https://apache-labs.com/community/viewforum.php?f=32
LA0GE
Re: Firmware
Post by LA0GE »
Hi and thanks for info.
Reason for asking which is the greatest was that I read some complaints about
PS not working in V6.0 so I thought maybe one of the earlier ones works better?
Re: Firmware
AFAIK 6.0 is good to go.
LA0GE
Re: Firmware
Post by LA0GE »
Hi.
Just installed 6.0 without problems.
Not tried PS yet so will have to see about that.
So far I have got everything working as I want.
Connected to Log4om and Jtdx via TCI and also N1MM with cw is working
as it should so now I'm ready for CQWW WPX :)
Next on the list is to get my Q5 transverters working and then compare it to my
Sunsdr2 DX.
Thanks again
Bent
Return to “Angelia Firmware (100D)”
