I assume that I would need to configure VAC2.
Most certainly yes, and if you are using ASIO on VAC1 you cant use ASIO on VAC2.JJ4SDR wrote:To configure VAC2, I am not sure if the Driver and Input and Output devices need to be different from those defined for VAC1?
Can someone send me a link to the relevant thread?NC3Z wrote:Most certainly yes, and if you are using ASIO on VAC1 you cant use ASIO on VAC2.JJ4SDR wrote:To configure VAC2, I am not sure if the Driver and Input and Output devices need to be different from those defined for VAC1?
Lots of info about all this in the forum.
