W2IHY settings for anan 8000dle
BIGBOY
Post by BIGBOY »
Before anything else Merry Christmas and Happy Holidays everyone! Does anyone use W2IHY system on their set up? I was recently gifted W2IHY 8 band EQ and EQ plus and I was looking for some settings for Anan radios but to know avail. If somebody uses this system maybe you can share some settings to start out with. Thanks!
Re: W2IHY settings for anan 8000dle
There's absolutely no reason to use a W2IHY box when Thetis provides many times the capability built-in.
With the box you get 8 fixed bands of EQ. With Thetis you get TWO separate EQ's with TEN bands of semi-parametric adjustment
With the box you get a single band compressor. With Thetis you get THREE separate stages of compression: leveler, CFC and ALC. And the CFC stage is a TEN band semi-parametric compressor.
With the box you get a downward expander with a single gain control knob. With Thetis you get a fully adjustable downward expander.
P.S. why on Earth did you post this in the "forum problems" section? Moved to the "audio hardware" section...
