MIDI Studio 2a
JeffH
MIDI Studio 2a
Post by JeffH »
Using a Behringer CMD Studio 2a, and Thetis, on a 7000DLE MKIII. Most of the functions can be mapped, but when I try to map any of the large wheels for VFO-A, The Max Value is 127, and the Min Value is 0, but the Value only shows 63 to 65 as I rotate the wheel, and after saving, the frequency only changes slightly.
Re: MIDI Studio 2a
I searched the topics for you and found this one: viewtopic.php?f=33&t=3892&p=22610
Not much there. If you find that one of those solutions works for you (Behringer driver, Windows repair) you might want to tack onto that topic your results.
JeffH
Re: MIDI Studio 2a
Post by JeffH »
My problem is a little different. I can map all the sliders and buttons, and knobs, and they work fine. The big wheels are the only thing that doesn't work correctly. As a side note, I originally had a Ryzen based computer, with that one the studio 2 would not work at all. Was reading on the web that some processors will not work with MIDI, so I switched to an Intel based computer and it worked fine, except for the two large wheels. You can see why it wouldn't work because when you rotate the wheel the value only changes by 3 digits, where all the knobs and sliders change by 127.
Re: MIDI Studio 2a
Do you have the Behringer driver installed? What version?
JeffH
Re: MIDI Studio 2a
Post by JeffH »
I had the windows driver installed first and it worked except for the wheels. I just installed the Berenger driver 1.7.0 there last one, they are not supporting the 2a anymore. the 1.7.0 worked the same as the windows driver, wheels don't work.
