MultiRX range
Posted: Mon Aug 14, 2023 1:05 pm
by ki4tga
How can i increase the range of the MultiRX so i can monitor vfoA and vfoB at the same time?
Re: MultiRX range
Posted: Mon Aug 14, 2023 1:16 pm
Could you please describe an example of a configuration that doesn't work for you?
Re: MultiRX range
Posted: Mon Aug 14, 2023 4:32 pm
by DO2ZA Erwin
simply use the Zoom
Edit: Of course, only in the same Band and a high Samplerate 384000 or moore
73 Erwin
Re: MultiRX range
Posted: Tue Aug 15, 2023 9:41 pm
by ki4tga
w-u-2-o wrote:Could you please describe an example of a configuration that doesn't work for you?
Right Here is on 10m and it wont let me activate it at that span. thats at a 768000 sample rate
Re: MultiRX range
Posted: Tue Aug 15, 2023 9:44 pm
by ki4tga
i can increase the sample rate to 1536000 and can so may just do it that way. ty
Re: MultiRX range
Posted: Wed Aug 16, 2023 1:13 am
ki4tga wrote:Right Here is on 10m and it wont let me activate it at that span. thats at a 768000 sample rate
Of course it won't. 29224 KHz - 28100 KHz is 1124 KHz. That is well outside your chosen sample rate, i.e. IF bandwidth, of 768 KHz.
You will be able to do this if you change your sample rate (IF bandwidth) to 1536 KHz.
Re: MultiRX range
Posted: Wed Aug 16, 2023 10:28 am
by ki4tga
yes on my next post i did so. ty for the quick response. i was unaware that sample rate=bandwidth. ty
