Tune drive level
JohnFT61
Tune drive level
Post by JohnFT61 »
In the Transmit menu, I have Tune use drive checked. Drive level for Tune = 10. The G2 will still output more power, according to where the Drive slider is set to.
John
N2KBE
KI4P
Re: Tune drive level
Post by KI4P »
Hey John, I THINK, if you have use drive checked, that is adjustable by the slide, if your talking about the window below that where you can put a percentage, that only works when you have use fixed drive, im having some crazy issues also.
i was going to use the use tune slider and it comes up with 10 on a couple bands and even 50 on a couple,, must have something to do with PA settings, i watched Richies video on how to set the PA but i only got 75 watts on a couple bands, still playing with it though.
JMO!
Richard
Richard - KI4P
JohnFT61
Post by JohnFT61 »
Richard,
OK, thank you for the reply. I will take a look at it after I solve another issue (microphone using front panel)!
John
N2KBE
Return to “piHPSDR”
