G2 and piHPSDR build 2 08 Pi reboots
dl4zbg
Postby dl4zbg » Sun Sep 17, 2023 9:27 pm
Not quite sure what happened to my G2 with display after installing the latest piHPSDR build from 16.9.2023.
When I shut down the power with the pushbutton (pressed for a couple of seconds), the pi reboots after 4s.
Anybody having the same problem?
Volker
JohnFT61
Re: G2 and piHPSDR build 2 08 Pi reboots
Postby JohnFT61 » Mon Sep 18, 2023 2:20 am
Volker,
I do not have that problem on my G2 with Display. I just upgraded it to 9/16/23.
I still have the problem when I have "COMP" assigned to the Top-Right Switch. In order for it to toggle, I have to press the Top-Right Switch
, and then the Bottom-Right Switch!
Also, the Encoder Menu still does not work correctly! What ever I assign to the Top-Right Switch, gets placed into the Bottom-Left Switch. I guess I will continue to make manual entries.
John
N2KBE
dl4zbg
Postby dl4zbg » Mon Sep 18, 2023 6:36 am
I think there was no update on the encoder menue. Same as before.
Volker
dl4zbg
Postby dl4zbg » Sat Oct 14, 2023 10:15 pm
Finally found an issue: if one plugs in a HDMI cable, the pi reboots, if it is removed, everything is fine. Looks like a "wake on ..." setting in the pi preferences causes the trouble.
