G2 Firmware update 5/10/2023
laurencebarker
There is an update to the Saturn software and firmware to help to address some of the audio issues that have been reported. Primarily this works with the recent piHPSDR release; but improvements to Thetis audio at high sample rates will be found too.
To adopt the p2app and Saturn FPGA changes, please follow the procedures in the manual. Basically these are:
open a command line window
type these commands (remembering they are case sensitive):
cd ~/github/Saturn
git pull --force
cd sw_projects/P2_app
make clean
make
cd ../audiotest
make clean
make
Then run the "flashwriter" app. The program may already be installed onto your linux desktop. If not you can run it simply from a linux command prompt. Open a command window then type:
cd github/Saturn/sw_tools/flashwriter
./flashwriter
click open file
navigate to the file ~/github/Saturn/FPGA
select file saturnprimary2023V10.bin
makes sure the Primary radio button is selected
click Program
(DO NOT click Erase Device or select Fallback!)
You will get progress shown in the window; it will go through erase, program and verify steps then report success at the end.
Shut your G2 down, power off and back on; it will now run the new FPGA code and will load the new p2app.
cd ~/github/Saturn
git pull --force
make clean
make
cd ../audiotest
make clean
make
./flashwriter
click open file
click Program
Re: G2 Firmware update 5/10/2023
Thank you Laurence, got it updated. Did have the merge error saying please commit your changes or stash before you merge. I deleted the P2APP executable and all else went as expected.
73~ John
73~ John
echo_india
Thanks Laurence. The firmware update went smooth here also.
Best 73,
EI5GJB
EI5GJB
Same hereK5WC wrote:Thank you Laurence, got it updated. Did have the merge error saying please commit your changes or stash before you merge. I deleted the P2APP executable and all else went as expected.
The updated firmware is very nice! It seems I can run 768ksps without any annoying audio glitches.
Edit: I begin to believe that with 192ksps in CW mode there are still ocassionally audio glitches. Less than before the update, but still too loud. Longer receiving periods in different modes are required.
Laurence,
After the git pull --force command I receive the following error.
Updating ad259ba..0add88c
error: Your local changes to the following files would be overwritten by merge:
sw_projects/P2_app/p2app
Please commit your changes or stash them before you merge.
Aborting
What should I do to resolve this so I can continue with the update?
Thank you,
Carmine K1VL
Aborting
Thank you,
Carmine K1VL
Carmine K1VL
echo_india
Carmine,K1VL wrote:Laurence,
Aborting
Thank you,
Carmine K1VL
you can cd sw_projects/P2_app/ then run 'mv p2app p2app_old'
Next, cd ~/github/Saturn and run the git pull --force again
Best 73,
EI5GJB
EI5GJB
laurencebarker
this is happening because git is distributing the p2app executable. It isn't supposed to do that because it is in my .gitignore file, but does it anyway. And the distributed one is 64 bit and won't run on a 32 bit distribution.
just delete your old p2app file; make will build a new one.
I tried to update pihpsdr on another G2 via remote connection and telephone call, but failed.
"git pull" came back asking me for an email address and some more annoying b/s.
How do I get that to work?
Run
git config --global user.email "you@example.com"
git config --global user.name "Your Name"
Ok, I will try that tomorrow. Thank you, Rick.n1gp wrote:Run
Thank you very much Laurence for all of your dedication and hard work you and the team are doing to get our new G2 radio up to speed!
John
KC2QMA
John
KC2QMA
Used git config, but run into more problems:DL8LAQ wrote:Ok, I will try that tomorrow. Thank you, Rick.n1gp wrote:Run
"...Pulling is not possible because you have unmerged files"
Solution found on stackoverflow:
git fetch origin
git reset --hard origin/master
Now the G2 is running fine with f/w 10 and pihpsdr 2023-10-04.
How do I delete the p2app file? Do I just move the p2app on the desktop to the trash?
Tnx, Jim K6JR
Tnx, Jim K6JR
Click on the terminal icon on the top bar to get a command prompt:
Then type:
cd github/Saturn/sw_projects/P2_app
rm p2app
make
Then type:
rm p2app
make
Thank you! This worked for me and I am upgraded.echo_india wrote:K1VL wrote:
Carmine,
Carmine K1VL
Carmine K1VL
