Mode Switching Issue..?
Posted: Mon Oct 09, 2023 5:34 pm
by John
The problem I am experiencing has been around for a while - normally not a big deal, until I start chasing a lot of DX requiring frequent mode switching. If I am running CW and then switch to FT8(DIGU) the 7000 will key but no RF. Shutdown/restart of Thetis allows FT8(DIGU) to function again. If in CW mode one can "tune" without the issue but as soon as CW is started even a single dit the issue appears when switching from CW to FT8(DIGU). Reset Database no help. Almost like VAC1 is shut off, although it is still selected.
Might be something I am missing here?
7000DLE MKII
Thetis v2,10.2
Firmware v2.1.18
Voicemeter Potato
John
Re: Mode Switching Issue..?
Posted: Mon Oct 09, 2023 8:48 pm
Hi John,
I am unable to replicate this, Could you send me your database.xml and ErrorLog.txt please. They are located in :
C:\Users\<user>\AppData\Roaming\OpenHPSDR\Thetis-x64 . My email address is over on qrz.
Thanks.
Posted: Mon Oct 09, 2023 11:41 pm
Hi John,
After looking at the DB it all looked 100%, however you need to enable 'Restore VAC1/2 device details from TX profile'. That option will then allow profile change to apply the audio devices that were in use when you saved the profile. Also, make sure the DIGI modes are using a different tx profile if this device switching is something you want to use.
Posted: Tue Oct 10, 2023 7:16 pm
by rdwing
I also have a bug where, if I'm operating SSB with PS-A on, then switch to CW and operate CW. Sometimes when I come back to sideband puresignal is just broken.
Posted: Thu Oct 12, 2023 1:32 pm
by PD3LK
make a new thread please :)
