PowerSDR PortAudio Error -9999 trying to use VAC
mnaruta
Post by mnaruta »
I need to get PowerSDR (HPSDR) VAC working with WSPR.
When I enable VAC 1 in PowerSDR, I get:
PortAudio Error -9999, Unanticipated host error
PortAudio Error -9988, invalid stream pointer
and the “Power” button goes off until I un-select VAC 1.
PowerSDR Setup: Driver MME, Input Line 1 (Virtual Audio Cable), Output Line 2 (Virtual Audio Cable)
WSPR used to work fine. What’s new is that I am now running Windows 10 and WSPR 2.6.1. My VAC is 4.13.0.5811. HPSDR is Atlas Mercury.
I am trying to get WSPR running for Saturday’s eclipse, but have been struggling for days.
AA8K
Re: PowerSDR PortAudio Error -9999 trying to use VAC
Try using Voicemeeter instead of Muzy VAC.
https://vb-audio.com/Voicemeeter/potato.htm
VB Audio is now offering a new tool called "Matrix" but I have not tried it myself.
https://vb-audio.com/Matrix/index.htm
mnaruta
Re: PowerSDR PortAudio Error -9999 trying to use VAC [solved] using VM Potato
Post by mnaruta »
Thank you Scott. I downloaded Voicemeeter Potato. It needs more knobs, buttons, and sliders. :)
The quickstart guides that I could find did not match any of the settings. So, I poked around until I got receive audio into WSJTX. It decodes fine now (Noon EDST). A little late, but I'm hoping that my data might still be useful. I'll try transmit later.
Thanks again Scott.
