Page 1 of 4
Thetis v2.10.3.3 released
Posted: Thu Nov 02, 2023 6:05 am
UPDATED to V2.10.3.3
Just released v2.10.3.3 here :
https://github.com/ramdor/Thetis/releases
Video covering it here :
https://youtu.be/rUj4ptaqhcU?si=EtFWNSPOBwikf_fW
Re: Thetis v2.10.3 released
Posted: Thu Nov 02, 2023 8:43 am
by liam
HI Richie Thank You for all your work.
73s
Liam
Posted: Thu Nov 02, 2023 11:19 am
by Tony EI7BMB
Thanks Richie
Posted: Thu Nov 02, 2023 12:33 pm
by Tony EI7BMB
Anyone seeing runaway audio issues using voicemeeter ?
Posted: Thu Nov 02, 2023 12:47 pm
by oe3ide
Tony EI7BMB wrote:Anyone seeing runaway audio issues using voicemeeter ?
Voicemeeter virtual ASIO or WASAPI?
Virtual ASIO is working fine here, For VM WASAPI I didn't find a working combo (buffer/sr/ringbuffer).
Presonus WASAPI is working great.
Posted: Thu Nov 02, 2023 12:53 pm
by Tony EI7BMB
Thanks Ernst . Using Virtual Asio.Think its local to here, seems MOTU M4 device and some other settings got reset somehow.
Posted: Thu Nov 02, 2023 1:14 pm
by Tony EI7BMB
Just noticed the radio model got changed so worth checking that after upgrade.
Posted: Thu Nov 02, 2023 1:41 pm
by W2QAQ
Thanks Richie.
However I'm running Win7 Ultimate and Thetis 2.10.3 needs .NET Framework 4.8.1 to run but .NET Framework 4.8.1 won't run on Win7 Ultimate O/S.
I know the simple solution would be to upgrade my O/S to Win10 but I really don't want to do that. So I guess I am stuck at v2.10.2.2
I would like to make one suggestion about the meters if I may. It would be nice to minimize the container(s) off the screen and be able to recall them in the same fashion as the band stack rather than to have to remove the entire container and lose all the meters within the container and their customized settings. As I said, just a suggestion.
Operating a 7000DLE Mk2 for over 2 years running Thetis.
Thanks again for all your efforts. Keep up the good work.
73, Harry W2QAQ
Posted: Thu Nov 02, 2023 4:59 pm
@Harry W2QAQ, I will re-release it in a few hours, and rebuild it for 4.8.0. There are probably going to be others impacted by this. It was not a change made out of necessity to be honest.
https://learn.microsoft.com/en-us/dotne ... mework-481
Ref the 'hide' option for meters. Yes I want this as well, I just haven't got around to it yet
Cheers.
Posted: Thu Nov 02, 2023 5:03 pm
@Tony EI7BMB, any chance you can email me your before upgrade db and the zip that you can get from setup->General->HW Select
Use the [Open DB folder] button and then navigate into DB_Archive folder. Old db should be in there.
Ta.
Posted: Thu Nov 02, 2023 6:46 pm
by Tony EI7BMB
Sure Richie , I'll get working on that
Edit : on the way to your qrz email
Posted: Thu Nov 02, 2023 6:55 pm
by Ernie
Bug report. When using DX Labs Commander, Thetis 2.10.3 will work fine until the power button on the GUI is clicked. That locks the entire GUI. The only way out is to kill Thetis in Task Manager.
Ernie
W2FMU
Posted: Thu Nov 02, 2023 7:00 pm
by ea4bas
Many thanks Richie for your very thorough work
Miguel, EA4BAS
Posted: Thu Nov 02, 2023 7:16 pm
by m1tzr
Thanks Richie
Can now come off digital mode without thinking my hearing has gone all muffled
You are a star, thank you so much
Paul
Posted: Thu Nov 02, 2023 7:19 pm
by W2SDR
Same issue as Ernie, W2FMU. GUI locks up when using DX Commander with CAT commands.
Posted: Thu Nov 02, 2023 7:38 pm
yes the issue has been identified regarding serial / commander
fix in the works
Posted: Thu Nov 02, 2023 10:56 pm
by wa1oxt
Fatal Error when installing 2.10.3. Win 11 Pro. WIn 11 update 23H2 _11/1/23.
12th Gen i7-12700K,3600Mhz. 12 Core(s).
Please see attached.
tnx ..OXT
Posted: Thu Nov 02, 2023 11:55 pm
try the following :
uninstall, reboot pc, re-install. Give that a try. Looks like PA19.dll did not get replaced with the new one for whatever reason
Posted: Thu Nov 02, 2023 11:59 pm
by wa1oxt
Will F/U within 24hrs..
tnx
gary
Posted: Fri Nov 03, 2023 12:13 am
UPDATED to V2.10.3.1
https://github.com/ramdor/Thetis/releases/tag/v2.10.3.1
v2.10.3.1 Change Log
[fix] serial data arriving could prevent Thetis from closing and could also cause UI freeze
[change] reverted to .net framework 4.8.0 to work with more operating systems
[change] added additional small buffer sizes to VAC config, 8, 16, 32
Posted: Fri Nov 03, 2023 1:09 am
by N3CAL
1. FATAL ERROR After install of Thetis v2.10.3. Tried uninstall and reboot. No Luck.
2. Then saw you released v2.10.3.1 so uninstalled v2.10.3 and rebooted. Then installed v2.10.3.1 and rebooted. No luck. Identical Fatal Error.
- Screenshot 2023-11-02 205101.png (16.56 KiB) Viewed 36512 times
N3CAL
Posted: Fri Nov 03, 2023 1:21 am
@N3CAL issue with 3 band EQ, bug. Will address in 2.10.3.2 in half an hour ... 2.10.3.1 was short lived. Next time we will do pre-release. Not enough testing/testers.
Posted: Fri Nov 03, 2023 1:31 am
by W9BHI
I also saw the problem with Thetis not wanting to close.
2.10.3.1 working and closing down OK now.
Don W9BHI
Posted: Fri Nov 03, 2023 1:34 am
W9BHI wrote:Richie,
Don W9BHI
cool, yes, Chris W2PA was testing as I was fixing
Posted: Fri Nov 03, 2023 2:05 am
UPDATED to V2.10.3.2
https://github.com/ramdor/Thetis/releases/tag/v2.10.3.2
v2.10.3.2 Change Log
[fix] resolved issue where a 3 band equaliser would cause out of array bounds exception
Posted: Fri Nov 03, 2023 2:21 am
by vk1hx
ramdor wrote:Not enough testing/testers.
I only just got 2.10.3 setup and running late last night... not much of a chance to test, but all good, I got 2.10.3.2 now and installing.
Ver 2.10.3 had some nice feature inclusions. I watched the short video on those and agree with moving the CFC audio graph thing into an options under meters. I would also suggest doing the same for the VAC buffer graph also.
Posted: Fri Nov 03, 2023 4:42 am
https://github.com/ramdor/Thetis/releases/tag/v2.10.3.3
v2.10.3.3 Change Log
- [fix] resolved DLL load issue for Win7 and other OS's that don't have SetThreadDescription()
Posted: Fri Nov 03, 2023 6:11 am
by vk1hx
God damn machine, I can't keep up...
Posted: Fri Nov 03, 2023 8:14 am
by W2QAQ
ramdor wrote:@Harry W2QAQ, I will re-release it in a few hours, and rebuild it for 4.8.0. There are probably going to be others impacted by this. It was not a change made out of necessity to be honest.
Cheers.
Good morning Richie,
Thanks a million. Just want to report that v2.10.3.3 is running on my Win7 Ultimate system at this moment.
Good to know that you will eventually get to the hide meters option. You're an amazing guy with the magic you perform for us.
On behalf of all of us Win7 users, thanks a million !
73, Harry W2QAQ
Re: Thetis v2.10.3.3 released
Posted: Fri Nov 03, 2023 8:21 am
by OE3JRC
Thanks Richie!
I use four loop antennes, three of them are for RX only with a more or less sensitive amplifier in them. One RX loop connected to RX 2, one on ANT2 and the third one on ANT3. I use CW a lot. Guess I am a lucky guy not using the CWX form, no serial CW/PTT, but a microHAM CW Keyer connected to the DIG IN 2, with Do Not TX in the Antenna Control of the Setup. My RX loops survived it...
Now enjoying the new version... Great work!
73, Hans.
