Could anybody please give me instructions how to interface Thetis with the N1MM spectrum display window. I followed the you tube video from MW0LGE but no sucess, Anan-Thetis and N1MM Spectrum Display.
When I open the Spectrum Display in N1MM I don't see any signals displayed. I can see the correct frequency assignment
in the right lower corner but the spectrum display is empty. Also when I pull down "For all other radios, Source named" I don't see the
page name,Thetis_1 like it is explained in the video.
Appreciate any help.
Thank you, Alex AK1MD
Interface Thetis with N1MM Spectrum Display window
Re: Interface Thetis with N1MM Spectrum Display window
Is this the video you are referencing?
What version of Thetis are you running? What version of N1MM?
If they are not the latest versions please update and try again.
If they are the latest versions, then please post screenshots of your Thetis and N1MM settings.
It might also be a Windows firewall problem. Try temporarily disabling the Windows firewall.
I am using the latest version of N1MM 1.0.10077.0 and Thetis v2.10.3.3x64 FW v2.1.7 Protocol 2.
I tried turning off Windows Firewall, however no success.
Thank you for your help.
Please see attachments.
73, Alex AK1MD
73, Alex AK1MD
- image (9).png (48.05 KiB) Viewed 13153 times
- image (8).png (35.19 KiB) Viewed 13153 times
- image (7).png (29.7 KiB) Viewed 13153 times
- image (5).png (413.98 KiB) Viewed 13153 times
- image (4).png (55.28 KiB) Viewed 13153 times
- image (3).png (262.34 KiB) Viewed 13153 times
Assuming everything is running on the same computer, change that 169... address to 127.0.0.1.
Okay I was able to resolve the issue. Thank you for your help.
It seems UDP ports have to be unique in N1MM.
I changed IP addresses and ports in N1MM Broadcast Data settings.
In Thetis Setup it required 127.0.0..1:13064
Thank you and 73, Alex AK1MD
- Spectrum display N1MM-Thetis 11092023.PNG (124.43 KiB) Viewed 13110 times
- Thetis settings 11092023.PNG (31.96 KiB) Viewed 13110 times
- N1MM Broadcast settings 11092023.PNG (24.39 KiB) Viewed 13110 times
