Split function
W9BHI
Split function
Post by W9BHI »
I noticed that the Split function does not work in the 11 meter mode. It works on all other bands.
Is this something that could be fixed in the future?
Thanks.
vk1hx
Re: Split function
Post by vk1hx »
73, Phil - VK1HX
W9BHI
Re: Split function
Post by W9BHI »
Running 2.10.3.5 U2. VFO A set to 27850 and VFO B set to 27950. Split button never turns blue when selected.
W9BHI
Re: Split function
Post by W9BHI »
A friend with an 8000DLE tried it and he gets the same thing, split not working on 11 meters.
Re: Split function
Yeah some issues there, will add to the list and look at it when I get some time/energy.
Green when selected stops the split from working even though band is not changing. Orange also causes some problems.
edit: AND region is extended (same for all countries it seems)
W9BHI
Re: Split function
Post by W9BHI »
I had the Disable Split on Band Change checked. Unchecked it and split on 11 meters now works!
Thanks for the quick reply.
Don
