Thetis and Elad TM-2 problem
qst
Post by qst »
I used Elad TM-2 with Anan 7000 DLE MKII and it worked properly. Now I connected it to the computer, configured two ports in VSPE like a splitter and enabled CAT in Thetis. ELAD is connected. No radio frequency displayed. F5 and F6 keys toggle. bands and this function works properly. Turning the VFO Knob changes the band to GEN. Is this a Thetis problem? I don't know where the problem is.
Slawomir
qst
Re: Thetis and Elad TM-2 problem
Post by qst »
Problem solved. TM-2 does not work on a split port created from a pair of ports in VSPE. You only need to create one port in VSPE and enter that port into CAT in Thetis. Everything works correctly.
Slawomir
