G-2 Fan noise
Posted: Wed Feb 14, 2024 6:08 pm
by KK4X
after a couple of months of using my G-2, I am experiencing louder than usual fan noise. has anyone else found this issue as well.
Group any recommendations to cure this?
Ed
kk4x
Re: G-2 Fan noise
Posted: Wed Feb 14, 2024 7:22 pm
by K5WC
I’ve had no issue with my fan but I saw this video showing the G2 fan and how easy it’s going to be to swap it out. About the 6:50 mark is the part about the fan.
https://youtu.be/yLDBr-FY9Ao?si=OxaUPHnctd_ykoJd
Good luck
Re: G-2 Fan noise
Posted: Thu Feb 15, 2024 12:05 am
by Jim
Ed, no issue here, the fan in my G2 is pretty quiet.
73 de KE4WY Jim
Re: G-2 Fan noise
Posted: Fri Feb 16, 2024 3:08 pm
by KK4X
Thank you all that replied.
Ed
kk4x
Re: G-2 Fan noise
Posted: Thu May 30, 2024 4:02 am
by brentc
I've noticed it as well with my G2. Now if I can find a fan like a Noctua but with the specs of the current fan.
-Brent
N9BC
Re: G-2 Fan noise
Posted: Thu May 30, 2024 11:01 am
by vk1hx
Re: G-2 Fan noise
Posted: Fri May 31, 2024 8:07 am
by Roger GT
NO !
The Fan in the top cover of the G2 is 120x120mm by 25mm.
Re: G-2 Fan noise
Posted: Fri Jun 21, 2024 1:17 am
by dchris
No fan issues with my G2, although I've only owned it for about 2 months. The YouTube link shows the 120mm fan installed by default in the G2. Based on my experience, there's nothing particularly special about this fan. If I were to replace mine, I'd get a Noctua NF-A12x25, which is the same size and a very high quality fan suitable for all-round applications. Link:
https://noctua.at/en/nf-a12x25-pwm
The connector is the same 4-pin PWM one as the factory-installed fan. I'd expect the Noctua to replace the factory-installed fan without any issues.
Re: G-2 Fan noise
Posted: Sat Jul 06, 2024 3:09 am
by KC9RF
The Fan you listed above Noctua NF-A12X25 PWM is the wrong voltage. It should be 5V with CFM of 52 also the 4 pin connector will need to be modified as there a two strips of plastic meant to fit in a specific 4 pin connector. If used you will need to trim down those two strips to enable it to fit. also did not see a CFM rating. Maybe someone could find that spec.
Bob KC9RF
Re: G-2 Fan noise
Posted: Fri Aug 02, 2024 12:33 am
by dchris
Great catch, Bob. Fortunately it looks like Noctua does make a 5V variant -
https://noctua.at/en/nf-a12x25-5v-pwm. The spec states only a 58CFM, which is maybe lower than what Fourdot reports (I find conflicting values when searching). I wonder how accurate the Fourdot fan specs are, though.
