Thetis full duplex ???
OZ1CT-Ben
Post by OZ1CT-Ben »
Is it possible to TX on RX1 and on the same time listen on another band on RX2 .. ????
I am building up a setup where I will use a transverter for 144mhz for local qso,and at the same time listen on HF at the same time.
Re: Thetis full duplex ???
I can easily listen to RX2 when I am TX'ing on RX1 (on seperate bands).
OZ1CT-Ben
Post by OZ1CT-Ben »
No special setup ???
Well you have to have your settings correct. Specifically make sure you do NOT have enabled General > Ant/Filters >Antenna > Gnd BPF2 on Tx
OZ1CT-Ben
Post by OZ1CT-Ben »
So you set Ur radio to only listen to RX2 and never TX, if you need then swap RX1 and Rx2 if you need !
OZ1CT-Ben
Post by OZ1CT-Ben »
trying to disable "Gnd BPF2 on Tx" but still no audio out....
but if you have it to worke then there maybe a chance I also get it to worke ;-)
tnx fer info.
73" BEn
KA5KKT
Post by KA5KKT »
You are using the second ADC for RX2, with a separate antenna?
