Thetis full duplex ???
Posted: Mon Feb 19, 2024 8:19 am
by OZ1CT-Ben
Is it possible to TX on RX1 and on the same time listen on another band on RX2 .. ????
I am building up a setup where I will use a transverter for 144mhz for local qso,and at the same time listen on HF at the same time.
Re: Thetis full duplex ???
Posted: Mon Feb 19, 2024 12:11 pm
by NC3Z
I can easily listen to RX2 when I am TX'ing on RX1 (on seperate bands).
Posted: Mon Feb 19, 2024 12:12 pm
by OZ1CT-Ben
No special setup ???
Posted: Mon Feb 19, 2024 12:15 pm
by NC3Z
Well you have to have your settings correct. Specifically make sure you do NOT have enabled General > Ant/Filters >Antenna > Gnd BPF2 on Tx
Posted: Mon Feb 19, 2024 12:31 pm
by OZ1CT-Ben
So you set Ur radio to only listen to RX2 and never TX, if you need then swap RX1 and Rx2 if you need !
Posted: Mon Feb 19, 2024 2:56 pm
by OZ1CT-Ben
trying to disable "Gnd BPF2 on Tx" but still no audio out....
but if you have it to worke then there maybe a chance I also get it to worke
tnx fer info.
73" BEn
Posted: Mon Feb 19, 2024 5:57 pm
by KA5KKT
Posted: Mon Feb 19, 2024 6:07 pm
You are using the second ADC for RX2, with a separate antenna?
