Good day Anan people.
Question, has anyone used the DU3500AL with their Anan and the OM2000A+? If so, what are the cables needed and the wiring diagraph?
Thx
DU3500AL Auto-Tuner w/ Anan 7000DLE MKII and OM2000A+
Re: DU3500AL Auto-Tuner w/ Anan 7000DLE MKII and OM2000A+
Sorry, I meant to use the word "Interfacing" I didn't have enough coffee when I wrote this.
HC5DX
David
Thx
HC5DX
David
Thx
Disclaimer: I don't have any of that equipment...
Looking at the manual for the DU3500AL it looks pretty straightforward. Page 16 shows the connections you need. The manual doesn't provide any detailed pinout information. Thetis supports Kenwood CAT protocol so you'll need to select that. You'll also need to provision a real RS232 serial port on your Thetis PC.
You might try contacting HA8DU directly for more info. I've read that he is very responsive.
w-u-2-o wrote:Disclaimer: I don't have any of that equipment...
Good day and thank you for responding. What do you mean by " Real RS232 Serial port"?
Thx
It's rare that we see a PC these days with anything but USB and Ethernet ports. The tuner provides an RS232 interface for communications. Thus an RS232 interface (aka "COM port") will need to be present on the Thetis PC. This means either adding an appropriate PCIE card (desktop PC) or a USB to RS232 adapter (any PC).
Thank you for this answer!w-u-2-o wrote:It's rare that we see a PC these days with anything but USB and Ethernet ports. The tuner provides an RS232 interface for communications. Thus an RS232 interface (aka "COM port") will need to be present on the Thetis PC. This means either adding an appropriate PCIE card (desktop PC) or a USB to RS232 adapter (any PC).
Hi been away from reflector,
OM POWER handles DU-3500AL control,
Transceiver port on OM amp to PC SERIAL PORT (optiplex SFF ) or USB to serial convertor
OM POWER amp rear panel . PC port out TO DU-3500AL TRANSCEIVER IN port on tuner
KENWOOD 38400bd ( set in OM CAT settings)
everything Tracks
I use ANAN 7000 / G2
with a hardware serial port on OPTIPLEX SFF commercial pc
COM 1 is an actual hardware com port,
Cheers
Dennis vk4sx
everything Tracks
Cheers
Dennis vk4sx
