Old CW keying topic revisited
JJ4SDR
Post by JJ4SDR »
Getting ready to operate in a big CW contest in May and exploring my options as far as keying the radio on CW is concerned.
I would like additional feedback from die-hard CW operators, especially those who are heavy into contesting!
Note that I am using a Solid State amplifier and will not want to see what an operator from the N1MM logging group.io page wrote:
***I stopped using the Thetis keyer function. Too often it had erratic timing leading to hot keying (evidenced by red flash around thetis display). Instead I now use an external winkey keyer. In N1MM+ you set this up in config. Enter the comm port assigned to the keyer (by windows), check keyer in N1MM+ configuration page. Click on set to choose winkey tab and click winkey.***
W2PA
Re: Old CW keying topic revisited
Post by W2PA »
Juha,
I use Thetis w/protocol2 on my 8000DLE driving a KPA-1500 and have no problem operating QSK with N1MM Logger+, or non-contest with an external paddle or CWX. I'm using delays of Key-Up=1ms, Key-Down=7ms.
Chris, W2PA
JJ4SDR
Post by JJ4SDR »
Thanks Chris!
Not sure why this other Thetis fellow is having those issues. Perhaps he didn't set the timing parameters....
JJ4SDR
Post by JJ4SDR »
Chris,
What RF Delay (mine is set at 100) are you using? I see my PTT Delay is 0!
W2PA
Post by W2PA »
RX Delay 0
MOX Delay 15
RF Delay 7
PTT Delay 0
You'll need to experiment, of course. Everyone's HW setup is a bit different. Note that RF Delay doesn't affect CW operation according to the tool tip.
Chris, W2PA
JJ4SDR
Post by JJ4SDR »
Copy that Chris!
Thanks.
W4WMT
Post by W4WMT »
W2PA wrote: MOX Delay 15
I've always wondered why one would want this parameter to be set to anything other than zero.
Can someone edify me please?
Bryan
W4WMT
W2PA
Post by W2PA »
Honestly, Bryan, I don't recall intentionally setting this. Maybe it was a default.
Chris, W2PA
W4WMT
Post by W4WMT »
Yes, that is the default.
I could just never figure why.
N4XD
Post by N4XD »
I'm that "other" fellow.
In the manual, which admittedly is quite a bit out of date, it said set CW delays (both key up and key down) to at least 30ms otherwise will get unusual results. Indeed I found, with other versions of Thetis, this to be the case. That and the long delay needed for all the relays to switch.
The easiest work around was/ is the external keyer. PLUS, the note on every firmware update, that RF may appear on the receive only ports you set up for a brief moment when using the internal keyer. That is not what I want so another reason to not use the internal keyer.
Ron
N4XD
