Problem changing IP Adresse
DL0815
Post by DL0815 »
Hello, i bought a used Anan 100.
The prev owner told me the IP Adresse 192.168.178.25
My own Network ist in teh range 192.168.0.x
If i usw my Laptop with a direct LAN cable thetis Connect to the anan.
But i am Not able to Change its IP Adresse.
HDSDR bootloader and HDSDR programmer will Not detect the unit.
Running Windows 10 and Protocol 2.
Any idea how to fix this?
Thank you in advance
Best regards
Willi
Re: Problem changing IP Adresse
Do you know if the unit is running Protocol 1 or Protocol 2 firmware? Knowing the answer to that will help determine whether you proceed with Programmer or Bootloader.
DL0815
Post by DL0815 »
Protocol 2.
Problem solved, i was not aware of the little switch on the bottom.
Now everything ist fine.
Thank you :D
