Drive level not saving per profile
ki4tga
Post by ki4tga »
Thetis V2.10.3.4 x64 for some reason my drive level setting isnt being saved per profile. as you can see in the screenshot it is not a highlighted save item. Why is this? thank you in advance
KI4TGA
Screenshot 2024-06-27 060445.png (513.74 KiB) Viewed 4251 times
Re: Drive level not saving per profile
Because drive-levels are stored in the pa-profiles.
73 Ernst, OE3IDE
ki4tga
Post by ki4tga »
Thank you sir. That's what I thought until I ran across a video where his changes woth tx profile. Just thought it is handy so when I would go to ssb the drive level could be set separately than the am and other modes.
https://youtu.be/LYpYS9rYSm0?si=Ncw0PuJvq4Qu88Nx
pa-profiles store the pa calibration which will define the max power attainable. The extra config can also be used to linearise the drive/tune sliders. On the front end/interface the drive/tune level slider positions are stored PER band. As a heads up, midi, andromeda slider form and a bunch of other stuff can make adjustments to drive level. Drive powers are not stored in bandstack data.
Trucker
Post by Trucker »
Ritchie, just a quick thank you. I just downloaded Dev3 and it works great.
( don't mean to hijack this thread)
ki4tga
Post by ki4tga »
Thank you so much for your guys help
