Drive level not saving per profile
Posted: Thu Jun 27, 2024 11:07 am
by ki4tga
Thetis V2.10.3.4 x64 for some reason my drive level setting isnt being saved per profile. as you can see in the screenshot it is not a highlighted save item. Why is this? thank you in advance
KI4TGA
Re: Drive level not saving per profile
Posted: Thu Jun 27, 2024 2:12 pm
by oe3ide
Because drive-levels are stored in the pa-profiles.
73 Ernst, OE3IDE
Posted: Thu Jun 27, 2024 3:33 pm
by ki4tga
Thank you sir. That's what I thought until I ran across a video where his changes woth tx profile. Just thought it is handy so when I would go to ssb the drive level could be set separately than the am and other modes.
https://youtu.be/LYpYS9rYSm0?si=Ncw0PuJvq4Qu88Nx
Posted: Thu Jun 27, 2024 5:20 pm
by oe3ide
- OQxisPYdJB.png (31.83 KiB) Viewed 4194 times
Posted: Fri Jun 28, 2024 1:53 am
pa-profiles store the pa calibration which will define the max power attainable. The extra config can also be used to linearise the drive/tune sliders. On the front end/interface the drive/tune level slider positions are stored PER band. As a heads up, midi, andromeda slider form and a bunch of other stuff can make adjustments to drive level. Drive powers are not stored in bandstack data.
Posted: Fri Jun 28, 2024 2:58 am
by Trucker
Ritchie, just a quick thank you. I just downloaded Dev3 and it works great.
( don't mean to hijack this thread)
Posted: Sun Jun 30, 2024 3:53 pm
by ki4tga
Thank you so much for your guys help
