Thetis V2.10.3.7 Final release?
vu2mb
Post by vu2mb »
I downloaded The latest final release from GitHub and the new flash screen of Thetis looks amazing.
I wonder if the announcement is not here in this forum, or if if there is something wrong with me as I am unable to see it.
Bhanu
VU2MB
thetis new logo.png (714.72 KiB) Viewed 9329 times
Trucker
Re: Thetis V2.10.3.7 Final release?
Post by Trucker »
There is nothing wrong with you. Even though the Anan radios use Thetis, it is something developed by volunteer developers not employees of Apache Labs. And they are not obligated to share their work. That they do is a good thing.
I suspect, without any actual proof, that updates may not always be posted on this website as it has in the past. The links to the Github repository in Ritchie's previous announcements for Thetis are still valid. So, it would be a good idea to check the repository every once in a while to see if there is something new that might be of interest to you.
If you are interested in helping with the development of Thetis, even if it is testing new software, check out the Discord link in Richie's signature line as well. If you get an invitation to join in testing, and you are able to provide feedback,that would help everyone.
You can also subscribe to GitHub and get emailed updates if you wish.
va7qi
Post by va7qi »
Actually, 2.10.3.7 was announced in the 2.10.3.6 thread. ....Erik.
Trucker
Post by Trucker »
va7qi wrote:Actually, 2.10.3.7 was announced in the 2.10.3.6 thread. ....Erik.
Look again, that announcement was for v2.10.3.6 not v2.10.3.7 which was released on Discord and Github just a few days ago.
Trucker
Post by Trucker »
I need to modify my statement slightly. What was announced in the v2.10.3.6 thread was a release candidate for v2.10.3.7. Not the final release that was posted on Discord a few days ago.
There are additional things that made it into the final release that may not have been there or needed additional work before the final release was announced there.
vu2mb
Post by vu2mb »
What I am talking about a final release and not a release candidate. I am using it and its not a RC.
Bhanu
2.10.3.7 final.png (16.23 KiB) Viewed 8897 times
Trucker
Post by Trucker »
Read carefully, it is not an announcement of the final release.
[quote="ramdor"]This issue is addressed in version 2.10.3.7, which is currently undergoing testing on my Discord server. You can join the server and become a tester to gain access. The Discord server link is available in my signature below. The release date is currently unknown. Here's the changelog so far from version 2.10.3.6:
v2.10.3.7 WIP Change Log
- [add] added OE3IDE Connectors and Tools link to the about box links
- [add] manuals added to about box links/manuals
- [add] new auto attenuate TX when PS is off options in Setup->Ant/Filters->Antenna
- [add] new auto attenuate RX options in Setup->General->Options-1. If the undo option is used the attenuation will be unwound in the order originally applied after each delay period
- [add] Discord integration, let others know when you are on air using the Discord button box. Get scrolling text for #general and #thetis-bot. Config in Setup->Networking->Discord
- [add] Backup prune implemented in Database Manager - GFS (grandfather, father son). Check to enable in the DBMan form (bottom right). Tool tip explains all
- [add] font colour added to button boxes (except for antenna box)
- [add] click colour added to button boxes (default orange)
- [add] warning shown in Linearity form if SetPk is different to that expected for the hardware
- [add] added Thetis bespoke input TCI command spot_simulate_click which simulates a user clicking on a spot in the spectrum. It causes a clicked_on_spot message to go out via TCI. Example test input msg, spot_simulate_click:MW0LGE,3750000;
- [add] added command line option, -noinstancewarn so that no warning is shown if other instances are running. Use -help in a console window to get more info
- [add] new filter item that will view the passband
- mouse wheel/click left-right when a number glows (10 steps default, ctrl single steps)
- drag filter edges in tx + rx
- drag top filter to shift in rx
- uses min/max spectrum grid values for waterfall
- can add notches with the [+mnf] button, and turn the mnf system with the [mnf] button, ctrl-rightclick to add one at the mouse
- drag notches
- right click notch to show popup for that notch
- mouse wheel over a notch to adjust width
- grid snap for common widths when dragging. These can be adjusted in Setup->Filters
- fill to container mode
- duplex mode is used for these displays, duplex off will not be provided
- uses new spectrum duplication system from Warren
- [add] right click setup menu item from the menubar will show setup instantly. To prevent all those repetitive strain injuries and to free up the doctors ! ;)
- [add] added -nospec command line option to prevent the use of analysers when the filter item is in use
- [add] webimage item can now be configured to apply the image to the spectral area, and can implement a slide show
- [change] moved release notes button from setup to the about box
- [change] skin images are resized to button/panel/slider etc instead of relying on tile property
- [change] button clicks are ignored in meter item button boxes that are faded
- [change] nf_1 and nf_2 has become nf, and will read from the trx container it is in (noise floor)
- [change] dragging the filter edges of am/sam/dsb etc will mirror the change to the other side. Shift to prevent this
- [change] adding a notch with +MNF when in CW will place it at centre of CW filter
- [change] refactored code that builds the H/W sample rate drop down
- [fix] inbuilt variables that have name with _double now consider %precis=N%
- [fix] resolved issue where redraw of console controls became very slow after 8thOct Windows update
- [fix] button boxes filter/antenna would not save columns correctly
- [fix] fade on rx and fade on tx fixed for button boxes
- [fix]
vu2mb wrote:I downloaded The latest final release from GitHub and the new flash screen of Thetis looks amazing.
Bhanu
VU2MB
vu2mb wrote:What I am talking about a final release and not a release candidate. I am using it and its not a RC.
Bhanu
Bhanu,
To be clear, there has been no formal announcement of Thetis 2.10.3.7 Final Release in this forum, even though that version is available for download from Github.
vu2mb
Post by vu2mb »
Bhanu
VU2MB
Bhanu
Bhanu,
Dear Mark,
Yes, that's what I understand now. Initially, I thought I missed something here.
Bhanu
VU2MB
W9BHI
Post by W9BHI »
V2.10.3.7 final was released on 12/4.
All the latest releases are discussed on Discord.
v2.10.3.8 is up on GitHub, just a few fixes in this release that were not squished in v2.10.3.7. Link in my sig below.
PH7R
Post by PH7R »
ramdor wrote:v2.10.3.8 is up on GitHub, just a few fixes in this release that were not squished in v2.10.3.7. Link in my sig below.
Ritchie, happy new year 2025 and many thks for all the updates and releases in 2024. Last version 2023 2.10.3.5 and see the enormous number of changes, fixes and new functionalities you have given us in 2024!
73 Ronald PH7R
