No PTT to Amp
va7qi
No PTT to Amp
Post by va7qi »
I am trying to get WSJT-X working with Thetis (20.10.3.6). A virtual serial port is set to asset RTS when WSJT-X transmit. It does key the radio and RF comes out, but the PTT output on the G2 Ultra to the amp stays high.
CAT control over a virtual serial control works fine. I am using HHD Serial Emulator.
73 de va7qi, ....Erik.
va7qi
Re: No PTT to Amp
Post by va7qi »
PTT when using WSJT-x does not work with Thetis 10.3.7 either.
I use one of the OC output as a work-around.
va7qi
Re: No PTT to Amp
Post by va7qi »
Disregard. It turned out that the tip and ring on the PTT in/out connector were shorted. They are now separated and PTT works as it should.
