Anan 100 no ip
VE2JN
Anan 100 no ip
Post by VE2JN »
I have a friend's anan 100, he flashed protocol 2, since then no more generated IP address, the radio still communicates I can put different firmware, change the IP address, but nothing to do it is never recognized by hpsdr or thetis even if I set the static IP
Do you have any ideas?
73’
Re: Anan 100 no ip
When booting into Protocol 2 firmware the ANAN will only communicate at GigE speed.
When booting into Bootloader firmware the ANAN will only communicate at 100MB/s speed.
Do you have a GigE connection to the ANAN?
VE2JN
Re: Anan 100 no ip
Post by VE2JN »
is there a way to check even if I don't have an ip address? to program I use HPSDRBootloader 2.0 no cap because the others don't work
sorry for my english i'm french
Re: Anan 100 no ip
No apologies necessary. At least you have some English, I have no French!
Also, Google Translate can be very helpful.
If you are asking how to check for a good GigE connection, if the ANAN is connected directly to the PC, use the LED indicators on any network ports, and also look at Windows Control Panel\All Control Panel Items\Network Connections and see if the connection is being reported at GigE speed.
Bootloader is always the best choice. It is a little more difficult but it will work every time no matter what firmware is loaded in the ANAN.
VE2JN
Re: Anan 100 no ip
Post by VE2JN »
right light (green flash) and left green stay on
Re: Anan 100 no ip
Is the ANAN directly connected to the PC?
What you look at the properties of the connection on the PC, what does it say?
