Mouse Click to Set Frequency
JPPNews73
Post by JPPNews73 »
Is it possible in Thetis to simply click on the frequency you want in the panadapter and have the vfo go there?
Richard Pritchard,
K5JPP
JPPNews73
Re: Mouse Click to Set Frequency
Post by JPPNews73 »
Well, now it works, as I remembered it. But it seems to be intermittent. Sometimes, when I click on a frequency (CTUN) engaged, it does nothing. and then later, clicking on a frequency works fine. Any thoughts?
Richard
k5JPP
AFAIK it only works with CTUN enabled.
With CTUN disabled you can right click to obtain a large crosshair and then left click to tune wherever that crosshair is.
W1SWL
Post by W1SWL »
From my experience so far if CTUN (which stands for CLICK TUNE) is turned off, you are in a "Bandscope Display Mode" if in Panafall.
Now, if CTUN is ON you are in "Panadapter Display Mode"
If CTUN button is OFF (unlite) , the left mouse button click and hold, will allow you to DRAG the panadapter center frequency either higher or lower when you move the mouse Left or Right.
If however, the CTUN button is ON (lite) then click and hold the left mouse button allows you to change the frequency WITHOUT changing the panadapter. However, I have noticed that if you go to the edge of the panadaper it may scroll a little.
There are numerous tuning options and methods, too many to discuss!
Many of these options and behaviors can be adjusted in Setup > General > Options > Options-1 > Miscellaneous.
I recommend you play with those and experiment.
Lastly, with CTUN on or off it is always possible to place the cursor in the frequency band at the top of the panadapter and drag it left and right. This is especially handy when in CTUN mode.
JPPNews73
Post by JPPNews73 »
thanks for the input on this mouse issue. I learned a few things, and that is always good.
Richard (JP)
K5JPP
