VAC on at startup?
w8du
VAC on at startup?
Post by w8du »
Hello Mates!
How to I get VAC1 to be active when I start up Thetis 2.10.3.8?
Even though I have checked /setup/audio/Enable VAC1, the next time Thetis starts up, it is unchecked. How do I get THETIS to remember this checkmark?
Tnx es 73 de Arnie W8DU
Re: VAC on at startup?
Post by Joe »
After you check the vac box the go to the transmit tab and do a profile save and I believe the next time you start it should come up checked.
73’s
w8du
Post by w8du »
Yep! That worked. Thank you for the quick reply and help.
73 de Arnie W8DU
Post by Joe »
Glad it helped. I have to be reminded quite often to save the transmit profile for the same reason when making changes, etc.
73’s
